phototec
Dropping water on the Japan's Fukushima Nuclear Plant from a helicopter at this altitude and speed, is only making a water mist and could not possibility re-fill the spent fuel rod pool!
The BBC is now reporting that “spent fuel rods in reactors five and six are also now believed to be heating up,” with a new fire at reactor 4, where more spent rods are stored, causing smoke to pour from the facility.
“Japanese news agency Kyodo reports that the storage pool in reactor four – where the spent fuel rods are kept – may be boiling. Tepco says readings are showing high levels of radiation in the building, so it is inaccessible,” adds the report.
“At the 40-year-old Fukushima Daiichi unit 1, where an explosion Saturday destroyed a building housing the reactor, the spent fuel pool, in accordance with General Electric’s design, is placed above the reactor. Tokyo Electric said it was trying to figure out how to maintain water levels in the pools, indicating that the normal safety systems there had failed, too. Failure to keep adequate water levels in a pool would lead to a catastrophic fire, said nuclear experts, some of whom think that unit 1’s pool may now be outside,” reports the Washington Post.
The rods must be kept cool because otherwise they start to burn and, in the case of reactor number 3, would release plutonium and uranium in the form of vapor into the atmosphere.
“That’s bad news, because plutonium scattered into the atmosphere is even more dangerous that the combustion products of rods without plutonium,” writes Kirk James Murphy.
“We’d be lucky if we only had to worry about the spent fuel rods from a single holding pool. We’re not that lucky. The Fukushima Daiichi plant has seven pools for spent fuel rods. Six of these are (or were) located at the top of six reactor buildings. One “common pool” is at ground level in a separate building. Each “reactor top” pool holds 3450 fuel rod assemblies. The common pool holds 6291 fuel rod assemblies. [The common pool has windows on one wall which were almost certainly destroyed by the tsunami.] Each assembly holds sixty-three fuel rods. This means the Fukushima Daiichi plant may contain over 600,000 spent fuel rods.”
 What does that mean? You worked with water and radioactive material before?
