Doming Resign Urethane
wildhock
Hello All,
I tried to pick-up on the other doming thread but it died so I am hoping someone may have some insight. Does anyone know if the product kits available by Fellers and other suppliers is a "flexible" urethane like used by Dometag? Looking for a small run application either through one of the kits or by other means if someone has first hand experience.
Thanks, Jon
digitalwoodshop
I do epoxy Doming using the UV Black Light Cure on tags.
I get the stuff from www.epoxies.com 401-946-5564
I use the stiff stuff... 60-7155RCL22
I believe the flex stuff is 60-7156RCL22.
They have the 2 part mix too.
I believe they make it so the price is better than through a supplier.
Good Luck,
AL
Just saw that the link in Post 2 is the same as I use...
