Dongle error
Discussion in 'Gerber' started by Billct2, Mar 12, 2005.
  1. Billct2
    Billct2 Major Contributor
    7,576
    679
    113
    Mar 12, 2005
    New England
    :help: When sending a file to the Edge, I often get a dongle error which say the computer "doesn't see the dongle and should it try again or go to demo mode".
    I hit no again and again to it goes back to normal, or I have to restart.
    This seems to have started happening after I upgraded to Omego & XP.
  2. Marekdlux
    Marekdlux Member
    50
    I was having this same problem. I had to do something with Rainbow Config. When I get home today I will check my email for the solution I was given.
    -Marek
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,920
    545
    113
    Sep 11, 2003
    Olympia, WA
    Check the Rainbow Sentinel Driver Config. It should be set so that the only port marked Yes is the port where the dongle is plugged into. If that doesn't fix it, then the next best possibility is that it is Windows XP Service Pack 2 related.
  4. Scott Reynolds
    Scott Reynolds Active Member
    828
    maybe try downloading the XP driver and in stall.
  5. Dale Horn
    Dale Horn Member
    222
    Check that the power is always on for the USB ports in the control panel. Power manangement can turn the usb port off so the software can't find it's dongle. :glasses:
  6. Billct2
    7,576
    679
    113
    Mar 12, 2005
    New England
    Thanks. Im going to try your suggestions.
  7. airbrushkarin
    airbrushkarin Member
    41
    I got an error like this too with my p2c know it is not the same as a great edge however I found that I solved it by changing to USB2 and not just the USB port. not a problem since I did that.
