Just In Don't cha just hate when this happens.........................
Discussion in 'Electric Signs & Channel Letters' started by Gino, Feb 12, 2020.
  1. Gino
    Gino Premium Subscriber
    34,362
    2,607
    113
    Jun 7, 2006
    PA
    • OMG / Wow! OMG / Wow! x 2
    • Like Like x 1
  2. rjssigns
    rjssigns Major Contributor
    5,302
    589
    113
    Jun 4, 2007
    Home Office
    Lucky no one got squished. Looks like the lift points ripped out.
  3. Z SIGNS
    Z SIGNS Very Active Member
    1,130
    179
    63
    Feb 14, 2009
    Trenton NJ
    some days are better than others
  4. Stacey K
    Stacey K I like making signs
    1,000
    455
    83
    Jun 20, 2018
    Wisconsin
    Oh boy...I would hate to be those guys! :(
  5. I hope they were taking that sign down and not putting it up :covereyes:
  6. Texas_Signmaker
    Texas_Signmaker Very Active Signmaker
    5,093
    1,879
    113
    Oct 21, 2016
    Frisco, TX
    So what's the lesson? If it's an old rusty sign, run straps around the entire thing?
    • Agree Agree x 2
  7. fresh
    fresh Very Active Member
    1,359
    124
    63
    May 16, 2011
    nj
    it was being removed to be refurbished, and yeah, they attached the crane to a rusty part which broke under the load.
  8. Gino
    34,362
    2,607
    113
    Jun 7, 2006
    PA
    No, make sure the poles are cut entirely and not to use your crane as a pulley system to break or snap steel.
    • Agree Agree x 4
  9. Texas_Signmaker
    5,093
    1,879
    113
    Oct 21, 2016
    Frisco, TX
    Oohhh, I see that now. That's not smart
    • Like Like x 1
  10. Johnny Best
    Johnny Best Very Active Member
    3,681
    2,073
    113
    Dec 9, 2015
    buffalo ny
    It looks like the crane strap broke. Glad no one was injured.
  11. FatCat
    FatCat Very Active Member
    2,044
    216
    63
    Feb 12, 2007
    Columbus, Ohio
    Yup, saw that and was thinking the same thing before I read your response - just a little bit of steel left and not cut through all the way. Looks like their bucket truck probably took some damage on the passenger side...ouch.
  12. Bobby H
    Bobby H Very Active Member
    2,259
    204
    63
    Feb 4, 2005
    Lawton, OK
    Ugh. That just makes my stomach turn watching that video. Not because it's stupid vertical video either.:D
    • Hilarious! Hilarious! x 2
  13. JBurton
    JBurton Signtologist
    2,200
    493
    83
    Sep 28, 2017
    Arkansas
    This is sheer laziness. He totaled a sign instead of taking the extra 3 minutes to boom over and see what was hanging up. I wonder if he was training the other guy in the basket, otherwise why were there two of them in there, and perhaps he figured the trainee had made a sloppy cut, but that the slag would give way. This isn't the crane operators fault, but he should have noticed the crane had the weight of half the sign already, and the other half was pulling his boom down...
    This reminds me of one of my first experiences with rope load line vs cable. We had a cabinet hang up half way down a pipe, so they pushed and pulled and finally gave up and figured on doing some more cutting/grinding on the pipe. I watched this sign come unstuck, after about 12" of load line had been winched in with no movement, and it suddenly shot up 2' and came back down 4" above where it started, which was about 5" above my installers head... I was on the ground and I ducked, he barely noticed.
  14. JBurton
    2,200
    493
    83
    Sep 28, 2017
    Arkansas
    I'd personally blow holes in the pipe, near the top, so a large shackle could fit it. It's hard to pull the pipe in two (see above video!) and tends to be the heaviest part, so if anything does give way or get hung up, you shouldn't have the majority of the weight falling. Otherwise, knocking a hole in the face and putting a strap all the way through the frame is a safe bet, just make certain you're not going to cut your strap on sharp edges.
    It's almost always better to cut the pipe free of the sign, as opposed to cutting the pipe and carrying both to the ground. I've seen some weld jobs that were just enough to keep the sign from freespinning on the pole. In those cases you could end up with a pipe dropping out of a sign in mid air...
  15. GAC05
    GAC05 Major Contributor
    6,164
    916
    113
    Dec 27, 2005
    Guam USA
    Take the sign to a detail shop, looks like it'll buff out.
    • Hilarious! Hilarious! x 5
  16. The Big Squeegee
    The Big Squeegee Major Contributor
    5,005
    122
    63
    Oct 10, 2005
    Lawton, OK, USA
    Looks like the bottom cabnet will need to be reworked too.
  17. XtremeXccessories
    XtremeXccessories Member
    202
    29
    28
    May 18, 2012
    Layton, UT
    I like how the guy in the bucket raised the cutting torch up like it was a lightsaber that he could use to cut the sign in half in case it was going to hit him.
    • Like Like x 2
