double sided print
BigfishDM
Print double sided on any substrate you can and apply optically clear double sided perm/removable mounting adhesive.
shoresigns
Assuming the clear vinyl has a white liner, you can print your registration marks on clear. I usually add a 0.5pt rectangular border outside of the artwork on both prints, then I can easily cut along that border on the white print, to line it up and apply to the clear print. Then cut using the registration marks.
ChicagoGraphics
If they don't need to be contoured cut, print reverse on clear then back it up with white vinyl, trim to size and install on inside of glass
