Downsaving
Discussion in 'Corel' started by CanuckSigns, Aug 14, 2020.
  1. CanuckSigns
    CanuckSigns Very Active Member
    3,509
    430
    83
    Nov 11, 2008
    Ontario
    Can anyone downsave a .cdr file from version 22 to version 18 for me? Client did a layout with the free trial but it's expired and they can't open it.
    I would install the trial myself but I've had issues in the past when uninstalling causes issues with my older version.
    I can email the file over
    TIA
  2. Ian Stewart-Koster
    Ian Stewart-Koster Active Member
    923
    21
    18
    Sep 27, 2003
    Qld, Australia
    I'd be getting the client to fix their own problem...
    How complex is it that you can't recreate it from a basic idea?
  3. WildWestDesigns
    WildWestDesigns Major Contributor
    6,616
    334
    83
    Sep 27, 2010
    5
    Try opening it up with Inkscape, that has been my go to for CDR files of late. No promises, but if isn't a very "sophisticated" file, it may be fine with Inkscape. Just make sure that you use the 1.0 release and I would do the portable one (it may be called binary archive), just in case it doesn't work, it's just delete the root folder and that's it. No traditional installer, so no issues with uninstalling.
    Otherwise, either replicate the general idea (I don't know how up for that charge that they would be for since it sounds like they were trying to do the artwork on the cheap as it is) or tell your customer to handle it in some way on their end and then come back. Unless, you just bite the bullet and update Corel.
  4. Lindsey
    Lindsey Not A New Member
    100
    27
    28
    Jan 17, 2013
    Canada
    Not sure if this helps...but I have 2019 and could give it a try.
  5. Big Rice Field
    Big Rice Field Electrical/Architectural Sign Designer
    222
    32
    28
    Feb 24, 2012
    Phoenix, AZ USA
    I have version 22 and I can downconvert it for you. send file to matthewbkota@gmail.com
