gnubler
Elementary install question, but what's the best way to drill holes through sheet metal and into brick? Use a regular drill to make a hole in the metal, then roto hammer into the masonry? Customer wants a sign to cover an old bank drawer that used to be in the building. You can see the black metal sheeting that's part of the window frame, which is what I would drill through into the brick to attach the sign. Behind the house wrap material is a metal plate but I won't be drilling into that, just the four corners of the sign (will use ACM). I'm open to any better mounting suggestions.
