Question Dry applying optically clear Laminate to glass
HecklnDecalr
I have a project that has print-cut frosted vinyl that has large open spaces so you can see through the window but also has pieces cut out of the main frosted part as well. I have laminated with optically clear to protect the print as cleaners may try to clean it. My problem is that I can't wet apply the lam as there are a lot of spots where the vinyl is cut where I'm sure fluid will be trapped. Will the optically clear lam that appears cloudy on the window now ever clear up? Will heat help it cure?
This was the first test window....I have 132 more to do. Do I need to search for better options? My customer already doesn't like my price so any option would need to be cost effective. Thanks for your time in advance.
