Dry erase marker
Berferful
Is there a particular brand of dry erase marker that works well with regular lamination (oracal 210). We occasionally do those large mounted checks used in press releases and I usually have the customer test their dry erase markers before using on the check. Some have problems, some don't. I know there is dry erase laminate available but I don't do enough to get a whole roll.
JBusch260
We've had good luck just with the regular ones we have here, the brand is Foray. I don't think they're anything special, but they work. I haven't let it sit on the surface much longer than a few test runs, but I think some Windex would work to remove if it sat a bit too long. 210 gloss obviously, right?
