Dumb question of the day.
Discussion in 'General Signmaking Topics' started by skyhigh, Aug 24, 2012.
  1. skyhigh
    skyhigh Major Contributor
    4,866
    10
    38
    Jun 16, 2005
    PA
    I've done hundreds of reflective signs this past year. Typically these are 36x36 or 24x24's. In the interest of saving time, I've been ordering in the blanks with reflective vinyl already applied (EG or HIP). The blanks always have "backer paper" in-between the individual panels from my supplier.
    Typically I throw the paper away, when I apply my vinyl. I then shrink wrap the signs together for delivery. If its a large order, I will group the similar lettered signs, and deliver however many bundles there are.
    (DUMB QUESTION COMING SOON)
    So.... 2 weeks ago I complete an order of 177 signs, consisting of 22 different formats of various quantities. I bundle them together in groups, and call the customer to arrange a palletized delivery. The customer asks me if I can store these for 4 weeks (they are paid for). .......ok, no problem.
    (ALMOST THERE).
    So today the customer calls........ they need one of these bundles for another job site. They tell me to make another 7, to replace them for the original order......... OK, no problem. So, today an employee shows up, and wants to unwrap the bundle to make sure they were exactly what he wanted.
    :frustrated::frustrated::frustrated: These F'n signs are fused together, and I had one heck of a time getting them apart. I ended up using a putty knife to snap the individual signs apart. None were damaged in the slightest.
    (HERE IT IS......)
    If I let these sit for another 2-3 weeks wrapped up......and they will let them sit for another 4 weeks (I know for sure, as they told me they won't be installing until the end of Sept - beginning of October), will this problem get worse? Is there a chance the vinyl can get messed up?????
    I really don't want to un-bundle all these signs, if I don't have to.
  2. Wiggum PI
    Wiggum PI Member
    298
    Oct 3, 2011
    Melbourne Australia
    start un-bundling...
  3. briankb
    briankb Active Member
    746
    1
    18
    Jul 7, 2009
    how did they stick but not cause any visible damage? you should probably keep that paper next time to keep between the signs in a bundle.
    live and learn.
  4. Billct2
    Billct2 Major Contributor
    7,463
    642
    113
    Mar 12, 2005
    New England
    hope your'e already prying them apart
  5. OlsonSigns601
    OlsonSigns601 Member
    405
    If you applied your vinyl wet?
    If so perhaps you stuck them together in bundles and they were still a little wet.
    Once the water evaporates it wouldn't be able to replace the water with air so it would create a vacuum between the signs.
    If that is the case, it probably wont' hurt them anymore than they already are. You can't get any more dry than dry.
  6. skyhigh
    4,866
    10
    38
    Jun 16, 2005
    PA
    i better unwrap a couple bundles to check. These were not done wet.
    I dont have a clue why they are sticking. Once i get the plastic putty knife in far enough to get my fingers in there;.theni can pry them apart but it didnt leave any marks on the face.
  7. heyskull
    heyskull Very Active Member
    1,663
    15
    38
    Sep 2, 2007
    UK
    I have also come across this problem.
    I don't know why but it doesn't always do it.
    Must be solvents of the glues on the vinyl coming through,
    So I always cover any sign blanks going out in silicon backing paper and tape to the rear as their is always rolls and rolls of that as waste of the laminator.
    SC
  8. ThinkRight
    ThinkRight Active Member
    810
    3
    18
    Nov 13, 2011
    Atlanta Ga
    Start saving that backing paper to sandwich between the signs before you bundle them.
    Maybe stacking them to to store them will be ok but do not bundle until you ship.
  9. FS-Keith
    FS-Keith Active Member
    721
    2
    18
    Dec 4, 2010
    pennsylvania
    yep I learned that lesson the hard way. Always paper them
  10. skyhigh
    4,866
    10
    38
    Jun 16, 2005
    PA
    to those who have experieced this problem, other than the inconvenience, has any signs gotten ruined?
    You may be on to something.....hmmmm. Good guess skull.
    I just did another bundle this morning. These were also "stuck" together, but not quite as bad. Again, nothing damaged or marked up.
    To better describe the experience......once I'm able to separate the corner (fingernail, utility knife, putty knife), I start to pry them apart, and they kinda "POP" when they release.
