DX4 Heads Question
Dizimoto
Hi,
Got a chance at some cheapish second hand heads. I'm on full Solvent ink, but these are down on the invoice as Eco Solvent Heads (DX4)-(M004372)
Are they the same part..?
Sorry if this Question has already been answered a thousand times on here...
Dizimoto
Ok so turns out they're the same apparently....next question:
The new heads have no ID on them.... The seller says it's not a problem
Can I just enter the Head ID from the old Head I am taking out.?
WalkerP
You don't need to necessarily input the head values. I've changed hundreds of those heads and probably input head rank 50% of the time. You may see some very very slight differences in print, but you should be OK. Always best to put the head rank in, but I doubt you will ever know the difference. Just leave it as is unless you see an issue after swapping it out.
