DXF file format?
Discussion in 'General Signmaking Topics' started by showcase 66, Jun 12, 2012.
  1. showcase 66
    showcase 66 Very Active Member
    1,833
    4
    I have a client that sent me a DXF file of his number plates for his race truck. This is the only file he has of the sizes he cut on his plasma cutter. Is their a way to convert it to an EPS or AI file.
    I am kinda hurting on time on this. My own fault. I miss understood what he said thinking next tuesday evening he needed them. But no today he needs them. I had the file since yesterday. :banghead:
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,555
    413
    83
    Sep 11, 2003
    Olympia, WA
    Open or import the file in Adobe Illustrator, FlexiSign, Gerber Omega, SignLab or CorelDRAW and then Save or Export it as EPS.
  3. showcase 66
    1,833
    4
    Thanks Fred
  4. showcase 66
    1,833
    4
    Cant get it into AI. Tried to place it in AI and still nothing. Says it is in a format which cannot be placed. Same as when you try and open it in illy. I broke the dongle on my Flexi so I cant get it in there right now.
  5. Deaton Design
    Deaton Design Very Active Member
    1,602
    2
    file..
    Email it to me and Ill try and convert it for you. Ive done dxf files in illus before. john@thetoonfactory.com
  6. Fred Weiss
    20,555
    413
    83
    Sep 11, 2003
    Olympia, WA
    Send it to the email in my signature.
  7. showcase 66
    1,833
    4
    Just emailed it.
  8. Christian @ 2CT Media
    Christian @ 2CT Media Major Contributor
    4,594
    710
    113
    Jun 15, 2009
    Mesa, Arizona
    Do you have Corel? DXF is a native format for Corel X4 and above.
  9. S'N'S
    S'N'S Active Member
    963
    25
    28
    Jun 5, 2008
    Australia
    I usually just right click on file and go to "open with" and select whatever program to open it ie corel, illus, etc but I just tried a dxf file and didn't work in IllyCS4 or CorelX3 yet opens fine in VMP, so if the others can't do it for you I might be able to.
  10. showcase 66
    1,833
    4
    John and Fred helped me out. Still not sure why I couldnt get it to work. I have done them in the past. At least I think I have.
    I did think of something just after getting everything done. I could have opened it in my AutoCad and then saved it as an EPS. Would have been very rough but it would have worked.
    Thanks again.
