E072err cr current
copythat
In process of printing two 27' banners. On the first run at around 20' I got this error message. E072err CR current.
Before I attempt to fix it, is there a way to save the first run or just reboot?
What causes this?
Thanks in advance
MacDaddy
4. Check if T fence is
contaminated or
worn out. Most Likely Not
5. Check "Y Encoder"
from "Test:
Encoder" of selfdiagnosis
function. Clean This.....................
6. Main board
assembly may be
damaged. Most Likely Not
:toasting:
