Headhunterx
Ok, I just got this used Agfa Sherpa 64 (AKA FalconII) and I have replaced all 4 heads and flat head cables (heads were already out when I got it so I did not start it up until I got the new parts ) So now I get this error and cannot get past it. I was able to updated firmware but no change. In the service manual it says it could be the CR board or the main board (hope Not) I ordered a CR board today but it won't be here until Monday I was hoping someone here has had this problem and knew if this would solve my problem and if there was a way to check if it was the main board or something else. these are the things I have already tried .....
1- Updated firmware
2- checked all the cables from cr board to motherboard
3- turned printer on with all cables disconnected from cr board
4- turned printer on with all cables disconnected from motherboard
5- turned printer on with head driver board un-pluged from motherboard
6- replaced everything and triple checked connections
7- Prayed
Nothing worked and still can't get past this..... Cannot even get to service menu.
Any Suggestions????
Thanks In Advance,
Richard
			1- Updated firmware
7- Prayed
Any Suggestions????
Thanks In Advance,
Richard
