There is a discount code in his signature - s101 - 30% off.
Yeah, one thing we have learned is that its a PAIN to set up the laminator machine! You really need to plan out 30 min or so to get it working right. Im thinking the squeegee method might even be better and faster for laminating as well instead of using the machine. We are going to have to run a couple tests
30 minutes??? you must have a diage it takes me maybe 3 minutes to switch out to a different laminate on my royal
Same here on our GBC Arctic Titan 165. Only takes a couple of minutes to swap rolls. Mounting, even faster, stick the board into the nip about halfway through, position the print just right, close the nip to the mounting position, flip the print on the feed side over the top, peel the backing till it's close to the nip, cut the backing off. Hit go and just make sure the print feeds in nice, one it gets to the end up the rollers back up, put the board back in the other way, close it, flip the print over the top, this side you can just remove the backing as it feeds in. Quick and easy.30 minutes??? you must have a diage it takes me maybe 3 minutes to switch out to a different laminate on my royal
You must be pretty goodThe biggest problem we have is getting the laminate to be flat on the roller. Our previous sign person recently left so we are having to learn a lot of this on our own for now. Even he hated setting up the laminating machine. There was obviously an easier way to place graphics on boards and laminate with a squeegee which I guess he didnt know about, maybe he also didnt know the best and easiest way to set up the laminating machine. He also didnt know about this website with tons of tips
As for the brand, it seems to be an "ABC Professional - 1064WFc"
