easy resetter for MUTOH valuejet.
floater302
Hello, Im lloking to see if any mutoh owners has a easy resetter they would like to sale... I had to replace my ink id boards and since i did that im getting the NOT ORIGINAL error, and i know its not the main or junction board thats bad.
wunder
if you have not update your firmware so check the wires from easy-reset......i think you have wrong installed
Change 1-2-3-4 to 4-3-2-1 and it will works ;-)
father
What do you mean by "easy resetter"? I'm not familiar with this.
floater302
The easy resetter is working fine, since i replaced all 4 ink id boards im getting not original error, but when i hook up my easy resetter it works fine.
Umca
Why you replaced ink ID boards?
This problem can happen if you upgrade main firmware, but not upgrade heater control firmware.
I has similar problem, but junction board was damaged. I am purchased service code and use printer without smarcard now.
floater302
The id board was replaced because the prongs broke off of them, so i replaced them all. Very seldom will the junction boards go out on valuejets but to be sure i switched it with an extra board i had and didnt help any, how did you get a code? and the firmware on this one is 1.2
Umca
This is standard service code for smartchip management system disable. I think fimware does not mater.
I've got this code from technician.
wunder
never hear about a service code to disable the smartcard on valuejet.....only a temporary disable function for 5 times and after restart the machine is smartcard detection on.
To disable, Mutoh use a update 2 files (firmware side)
ignacio2030
easy ressetter for MutohValuejet
Dear consultation ? Where I can get a deactivation code chip for Mutoh vj - 1204 and as installed, here in Chile to charge me $ 1000
for this service, appreciate your help
Dangreenst
Does anyone have Mutoh bypass code available for 1624?
