Eco Solvent Ink Dryer
Discussion in 'Product and Supplier Referrals' started by rydods, Dec 11, 2019.
  1. rydods
    rydods Member
    324
    43
    28
    Feb 15, 2007
    Wisconsin
    My goal is to speed up drying time, preferably be able to laminate right away. I have 2 eco-solvent roland printers.
    Does anybody have or know of a drying unit? I've seen several online but I'm curious to know if any work for immediate lamination after printing.
    This really isn't meant to start a debate about out gassing myths or facts. :)
    Thanks in advance!
  2. SignMeUpGraphics
    SignMeUpGraphics Very Active Member
    1,455
    316
    83
    Apr 11, 2012
    Australia
    • Like Like x 1
  3. JimMoorePDS
    JimMoorePDS Mimaki Sales & Service Technician
    • Like Like x 2
  4. rjssigns
    rjssigns Major Contributor
    5,197
    541
    113
    Jun 4, 2007
    Home Office
    If you're on a budget a couple quartz tube space heaters will work. I've done it. They have small fans in them so you get infrared heat with air circulation.
    Can check into auto body supply shops too. Should have all kinds of infrared heaters on stands.
    • Like Like x 1
  5. Gino
    Gino Premium Subscriber
    34,169
    2,562
    113
    Jun 7, 2006
    PA
    Basically, solvent inks are no different than solvent screen inks or solvent paint. It simply needs air movement. Set up a rack and put a fan on it and lay them flat, if you can, like a screen printers rack. We do it all the time, but not so we can laminate any faster, just to help cure the inks faster. The heat notion comes in to play from baked surfaces. Heated air makes for faster evaporation time so, heated air blowing over the prints will work even better. If you overheat with those lamps and things, you could cause more damage than just pre-laminating.
    • Like Like x 1
