ECOUV Primer for Roland VersaUV LEJ-640
bwright
I am printing on material using Roland VersaUV running EUV4 Inks. I have a material that I would like to enhance adhesion and discovered a primer. However, I'm unclear as to whether I can use the cartridge. The Primer is EUV. Would this be compatible with my machine to use in the GLOSS slot (I don't use gloss). Roland does so CMYK, WH, GL and PR are available for EUV4...but this EUV PR is all I can find. I'm not sure if it's universal. Any help would be appreciated.
balstestrat
Problem Solver
Not really saying anything about the details but overall Gloss is usually the last to be put down and primer needs to be first. So you can't use that head for it even if you were to rig it somehow because it's in the wrong position.
I don't think that LEJ supports primer... I would just try with manual priming first, to see if that even helps you enough.
