edge 2 minutes
signage
That come to approximately 62.5 hours! what do you think? The amount of minutes is almost irrelevant being a print head can go bad at any time! But it doesn't sound over used it sounds under used!
The edge II is under used, check the print head with a test print to make sure it is good. That machine will be a good find for someone that can put it to use.
