Edge Hours
Bell Signs
How To Print Minutes for EDGE Machines
We would like to make you aware that there is a way to find out the print minutes on an EDGE or EDGE2. This can be done on all the EDGE2 machines and on the newer EDGE LE machines. Finding the print minutes can be useful whenever you may need to determine the usage a machine. (Such as the trade-in value)
Note: Some older EDGE's will not have the ability to do this.
Here are the steps:
1. With the EDGE on, press the reset button so the display reads OFFLINE
2. Press and release the SETUP button to view the next setup screen. (It should read test pattern)
3. Keep pressing and releasing the SETUP button to scroll through the screens until it reads PRINT MINUTES. (About 22 times)
4. This will give you the minutes the EDGE has been printing.
Note: This number may not be accurate if the EDGE has had the print-head or CPU
Taken From Advantage Tech Tips
