Edge II Connectivity
Mikeb64
I have acquired an Edge II that used to be on a network. When I put the Edge II online, I have
50 188 25 I am connecting with a cable directly to a USB. How do I re-set the Edge and Envision 375 to recognize that they are no longer on a network and being connecting with the correct cables?
Fred Weiss
Not the way to do it. You need to have software that will rip for that printer. Examples are:
Gerber Omega
Flexisign Pro
SignLab
Mikeb64
Hi Fred! I do have the right software, I have Omega 6.5. I have installed, in-installed, done everything that I can think of.
Fred Weiss
You don't have to get into anything to do with port settings. You will need to get the Gerber supplied USB to Parallel connection cable for it to work properly and then you install it using the System Tray utility.
Attached is a Gerber PDF that addresses your issue on the second page. I had some difficulties getting mine to work and GSP support got on the phone with me and got it fixed. They also strongly suggested that I always have the cable in the same USB port once they got it to work correctly.
  • OMEGA_Requirements_65.pdf
Mikeb64
Yes sir, I have it. It’s the cable that plugs into the back of the Edge and the other end is the USB that plugs into the computer. It came with it.I will try the steps in the document, worst case, I talk with Gerber on Monday. Thanks for the Info!
