Edge Minutes
Marie
To find the minutes that you have run your Edge (I have the oldest model - opens to the side), I thought that you pressed the "invisible" set up button (on the left of the keypad under the reset button) until Print Minutes comes up - but Print Minutes never comes up on my list??? So... how do you find out the run time on this printer? Thanks!
J Hill Designs
gosh, i dont know, but thanks for letting me know I have invisible buttons! whoa...
what I'm finding online is it should say it, but mine doesn't either..
Marie
After 15+ years of use, the invisible button on the right side of the panel is VERY visible :)
Malkin
On ours, an EDGE LE (beige color, opens in the front) I just hit the setup button many times until it gets to the print minutes. Ours stands at 75,425. I am pretty sure we have had it from new.
The invisible button seemed to want to do some sort of test print.
signgirl
I believe I have read that this is not an option on the first edge...I have one also when I run thru it, it does not show
