dlndesign
I have a Concept General Formulations low tack vinyl gloss laminated that I applied to 6 Brass Elevators Doors.
They were up for 24 hours for an event. I went to remove the graphics and the adhesive remained and just the vinyl pulled of with no adhesive on the back. I had given some heat to the vinyl prior to removal, but that did not work.
It took a few hours to remove the adhesive off the doors.
My question is what is the fastest remover that will cut through the layers of adhesive and still not damage the surface of the brass doors?
What we are currently using is rapid remover, goof off and squeeges and then once the adhesive is off some brasso to final touch.
Does anyone have any suggestions to make this removal any easier?
