elevator handrail graphics
mikeinpdx
I've seen some of the elevator handrail graphic advertising, which I thought seems pretty cool. If you've applied these sorts of graphics, what equipment did you use? It appears like some specialized equipment is needed, based on what I found searching around, at least if you want to do it quickly and have a full wrap look to it ( top and sides). http://www.adrailusa.com/productinfo.html
Has anyone ever tried applying just a removable vinyl (IJ40? ) strip down the middle for a lower cost solution? I'm not sure it's worth the liability issues though.
