Encad Vinyl Jet Questions Please help!!!
Discussion in 'Miscellaneous Printers' started by word13, Aug 28, 2005.
  1. word13
    word13 New Member
    5
    Hey guys,
    I'm getting ready to buy an encad Vinyl jet and was wondering if anyone who uses one can give me some info on them? I'm useing it for outdoor only applications similiar to car wraps printing advertisements full color heavy layout and full color pictures not much text more actual pictures of products. Is this machine good for that? Does the print quality look good? My ads are only 12 inches by 48 inches?
    Any comments?
    d-
  2. Barry
    Barry Active Member
    659
    May 6, 2004
    Isnt the Encad an aqueous-based printer that runs either dye or pigment based inks. If this is the case its probably not a printer I would choose to purchase for outdoor use. Coated materials are significantly more expensive then the uncoated materials avaible for the eco-sol/solvent printers. The dye or pigment based inks just will not last long term even with lamination.
    Your best bet is to pickup a 30" versacamm. This is about the cheapest you can get into a reliable outdoor machine right now. There are quite a few used machines up for sale right now since people are upgrading to the larger 54" model. Used machines can be found in the $8,000-$11,000 range depending on condition and extras that come with it.
  3. jayhawksigns
    jayhawksigns Very Active Member
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    The VinylJet was the printer that would "cure" the vinyl so that you actually encapsulated the ink into the vinyl. Supposed to be the best outdoor durable aqueous printer you can get, for the price.
  4. word13
    word13 New Member
    5
    I belive that is the case.
    The vinyljet is supposeed to print on uncoated vinyl keeping the media costs and ink costs together down to about 68-78 cents per square foot. I was wondering if this would be good for printing of outdoor vinyl signs similiar to car wraps.
    here is the link:
    http://www.encad.com/Printers/Discontinued/VinylJet/index.asp
    Any feed back would be more than appreciated!!!
    thanks,
    d-
