Encoder strip
Jim Hill
The colors on my SP-300 have a faded or washed out look to them and I was wondering if it could be time to replace the encoder strip.
I have cleaned a few times without it making any difference.
I have also done a powerful cleaning and a medium cleaning without it helping to improve the colors.
I have also done a manual cleaning thinking there might be something on the heads.
Any idea what might be causing the problem?
Thanks Jim
rjssigns
Need more info, but a dirty encoder strip will usually only cause fuzzy edges. Could be time for new cap-tops. Could have a clogged line/head. Did you run a Fill Test to see if it's a starvation issue? Could be a corrupted file. Lots of things may be causing it.
Profiles, head heights, cleaning, contaminated media.... even possibly old stale inks could all be plausible culprit.
brentriley
Thanks Jim
Was it the Encoder Strip? I think min is going bad
artbot
it's a micro film that the head carriage's encoder sensor reads/counts left and right to confirm position for firing. when it has dirt (or speck of ink) on it, the sensor will skip a count and the print will start drifting right, staggered like stair steps. prints drifting to the left are a sign of an electronic issue with the sensor (dirt on a strip can not "add" to a count).
@jimhill, is the "washed out" look due to white spaces between the dots? are you in bidirectional? i'd do a bunch of testing in unidirectional compared to bi-. also static can cause microscopic misplacement dots causing white negative space and ink whisping away from the substrate causing a loss of density.
