Something strange is happening with our Envision and I'm out of ideas.
When we send a job to the cutter, it cuts the target then follows the cut paths but without lowering the blade, so the job isn't cut out. It doesn't happen on every job, only some jobs, but we can't see any pattern or correlation between the jobs that don't cut. One job doesn't cut, the next job cuts just fine, even if the job is larger in size, longer, more detailed, same colour foils etc.
Here's the strange bit. At first we thought there must be an issue with the artwork, so we resaved the files but it still doesn't cut. So we recreated the files from scratch with fresh artwork. Same problem. Then we recreated the files with black only (no other foils). Same issue. Then we put the cut paths on a separate layer, different colour, same stroke width, checked the files for stray points, empty fills, text etc, Nothing. The files are clean but it still refuses to cut the same jobs, no matter what we do with the file setup.
Why would the cutter have the same issue with multiple versions of the same artwork? Why would the cutter not lower the blade, even though it follows the cutpaths?
Any input would be much appreciated!
Cheers!
Cheers!
