gabagoo
I still need my edge to print white on clear and that is about all I use it for. I don't change blades in this machine too often and my old blade needs so much pressure it was scoring right through one cut on every decal, making it very hard to deal with. I finally found a third part blade and installed it yesterday. Ran a pile of tests and can't believe how much pressure I had to use to do a decent cut. 40 grams on a new blade? I realized that the cutting strip was pretty worn and figured this is what all the fuss was about...removed it cleaned out the channel it sits in and applied double sided tape and used the back side of the strip. I have to think that would work. Tested some more and still seemed to need a lot more force than I would think based on using a new blade. Ran 3 runs about 3 yards each of 2" x 2" square decals. Weeding this morning, the first one weeds flawlessy, then the second weeds about half as good with many decals lifting and not cut right through. The third piece was total trash.
I am now sitting here and I have no idea how or why it is acting up. I can't seem to figure out what else to try. Maybe you can't flip over that cutting strip, but I can't see why, outside of that I am ready to just let customers know that I can no longer print white on clear.... what else can I do?
