eps file - cannot cut
Discussion in 'Adobe' started by signw1zard, Dec 19, 2005.
  1. signw1zard
    signw1zard New Member
    4
    Hello All (newbie alert)
    I received an eps file from my customer, but I can't make it into a cuttable file. When I open it with Illustrator, it appears bumpy. I thought eps files were vector. When I go into outline mode it shows a box only.
    Customer says this is all they have. What can I do to the file to make it cuttable?
    Joseph
  2. ENTDesign
    ENTDesign Very Active Member
    1,050
    Unfortunately bitmaps can also be saved in eps format. You will have to convert the image into vector art which you can do using the tools in Illustrator, or you can pay a service to do it for you. One of the members here does this as a business, the Vector Doctor. Check the threads for the last week or two as this topic was recently discussed.
  3. tiamarie
    tiamarie Member
    101
    (From another newbie) Sounds like someone saved the raster art as a eps. (Basically they may have opened a jpg or whatever in Illustrator then saved it as an eps) Doing that doesn't magically make it vector art. The artwork will need to be redone.
  4. signw1zard
    4
    Thanks, I'll give them a try. The logo uses a font I don't own.
  5. signw1zard
    4
    Thank you ENTDesign for pointing me to the vector doctor. I sent the file yesterday and I got it back late last night. It was perfect, saving me an hour or more of time and I would not have been able to do it as good.
  6. Robert
    Robert New Member
    7
    Yup Yup, The Vector Doctor Rocks! I just started my little shop last month and have used Eric on several images. Let's me get over the learning curve on my own time while still recovering some of my initial investment. I pass the conversion costs onto the customer but have low overhead so they don't feel the "pinch" of it. I don't markup erics work, I just pass the costs along.
  7. sullosau
    sullosau Active Member
    537
    Ericws a legend at the vectoring, but I would like to know how to convert a jpeg bmp etc into a eps. Until then erics employed there, great employee too no benifits, no holidays no wages to pay just an occcassional cost here n there :)
    Just kidding I thoroughly recommend eric the vector doc
    Steve
  8. Shovelhead
    Shovelhead Major Contributor
    10,882
    15
    Did anyone mention....
    to try to import as an interpreted postscript EPS????
  9. bob
    bob Major Contributor
    5,257
    303
    83
    Nov 4, 2005
    earth
    EPS==Encapsulated Post Script.
    Ecapsulated, as in a wrapper. An EPS file is a container for layers of vector, text, and raster objects. What was put into the file is what comes out of the file.
    If a bitmap comes out of an EPS file then a bitmap was put into that EPS file. If that's all you have and you must cut then you have to trace or hire a subordinate to trace for you.
  10. Jeizzavelle
    Jeizzavelle Member
    91
    I am a kinda newbie (htought I was doing good till I found here) but I know that I get those alot and if you are using Omega you can try under tools- Posterize.
    Sometimes it's great and sometimes you get a bunch of crap. Even when it's great though you have to clean it up. Usally it's not too bad though. Hope that helps!
  11. The Big Squeegee
    The Big Squeegee Major Contributor
    eps files
    If you can get the file converted to curves before they send it to you, you won't need the same font.
