Epson 9700 problem
Discussion in 'Epson' started by iladi, Jun 27, 2012.
  1. iladi
    iladi Member
    120
    Apr 23, 2007
    Romania
    Since the first day the printer was fueled with dye ink. Now I switch to pigmented ink. OCP Germany is the manufacturer. I heard is a good one. The problem is I am loosing magenta and black while printing. Heavy. About 25%. After a while, if the printer sits idle some nozzles come back. Anyways, A normal cleaning cycle brig the nozzles back.
    What can it be? Ink? Dampers? Printer is 1,5 year old, heavy use, Epson 9700 Pro.
  2. Dyllan
    Dyllan New Member
    1
    I have had this problem before. You have to be careful what inks you mix together, some have a bad reaction when mixed together and become a bit thicker which blocks the dampers. I solved the problem by removing all the ink from the pipes and replacing the dampers. Hope this helps
