Epson 9800 print problems / head problems ?
mortil
Hi. i got a epson pro 9800 that have worked perfect over the time i had it.
in the beginning of this year i had a clogged head but i took the head out and cleaned it after that it worked great but this week when i started printing everything just wanted to be green and i got lots of lines in my print.
the colors became worse and worse. so i took it out made the exact same thing as in the beginning of this year. but when i gently pressed air through one of the nossle inlets ink started to flow up from all the other ones.
this is not how it should be right ? or ?
under this year i have printed loads of stuff on this printer and everything with perfect outcome.
anyone got any idea ?
oh yes. and when i blow air in for example yellow inlet it pushes ink out of all other inlets and all nozzles in the head.
is the head dead ?
