News New Guy Epson DX4 Deflection
Discussion in 'Digital Printing' started by simigliani, Jun 21, 2020.
  1. simigliani
    simigliani New Member
    2
    Aug 10, 2012
    Mar del Plata
    Hi, how are you?
    I am having problems with my Roland VP540 printer with Nazdar inks.
    I have several theories but I need to know exactly what the problem is to solve it or prevent future damage.
    It started in April. We received complaints from some customers about changing colors and noticed that the turquoise began to print very greenish and the reds turned magenta ...
    When we saw the testprint, we thought that part of the yellow had been blocked, so we changed dammpers and captops, but it was not the solution.
    Later we realized that it was not that a section of the injectors was not firing, in fact they were deflecting (they defect so much that they generate a "hole" in the test giving the feeling that they are not there)
    We are temporarily printing hiquality but it is not the great solution ...
    I have more heads but I don't want to put them on until I am sure of the problem that caused this.
    Any suggestion?
    Last week the same thing started with the magenta so we are more complicated
    Attached technical report and Test Print
    [​IMG]
  2. unclebun
    unclebun Very Active Member
    Head soak, disway wash. Try again.
  3. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,238
    797
    113
    Aug 2, 2011
    Denver, CO
    Head 3 has fired more than double the shots it is rated for. head 4 is at about 150% of it's life time. You could try soaking and flushing but at that amount of shots fired, the nozzles are most likely just deformed which causes the deflection.
    • Agree Agree x 1
  4. Jim Hancock
    Jim Hancock Member
    442
    78
    28
    Nov 11, 2008
    Delray Beach, Florida
    Based on your nozzle test and shot counts, it looks like you are due for 2 print heads to be replaced...
  5. simigliani
    2
    Aug 10, 2012
    Mar del Plata
    Hello again. And thanks for responding. I understand that they exceeded their useful life, but it seems to me a lot of coincidence that they break down yellow and magenta almost at the same time. And the symptoms are very similar. I had not happened with other heads that change. My fear is that the same will happen to the new ones.
