Saturn
Aging Member
With a new modem brought some changes to the LAN IP addresses.
I use my own router, and plugging that straight back in seemed to work fine for all devices except for the printer connection to Epson Edge Dashboard. My RIP and printer talk just fine with new manually paired IP addresses and I can print as I always did, but EED doesn't seem to have a way to manually update an IP address. The refresh/search does not find anything. (Obviously I run my IT department with luck, not knowledge... )
Network issue of my own creation? Or can I uninstall/reinstall something related to the EED (Comm Driver?) and get back to square one without fear of mucking things up worse?
Side question, is EED "required" for anything other than downloading profiles or manually circulating ink? I plan to add white ink in the future and that's the only reason I would really worry... I never do anything in EED other than leaving it open in the browser 90% of the time—the 10% it's no open seem to indicate it's not mission critical.
