Good day,
Yesterday I noticed my gs6000 was dripping ink, I took a closer look and the drain tube was clogged, so I took her apart per the manual and fixed the clogged tube, I checked all of the other tubes and one more was clogged, it connects to the bottom of one of the caps and goes to a part at the right end of the maintenance station, anyway I unclogged that tube and put her back together, I then ran a nozzle check and it did not look good, so I ran a couple heavy cleanings and nothing changed it seemed to get worse.. Ive cleaned around the caps and flushing pad I performed the carriage maintenance and nothing has improved, I attached a pic of the nozzle check,, would bad caps be the cause of this?
prior to fixing the drain tube clogged the nozzle check was perfect..
