EPSON GS6000 PF Motor
rdm01
Hello,
Was welcomed by the shop this morning with one of our Epsons giving an Error 1227, which is a PF Motor Step Out Error. Motor looks easy enough to change, but when I look at it and spin the shaft, there is no binding/grinding, anything you would expect from a motor that is dead or dying.
Anyone have any expertise on this one. Might another part be causing the problem. I would hate to replace the motor and have the same error, or chase to a new error and wait for parts again.
Thank you in advance for any tips.
I'm not sure if the GS6000 has a PF encoder disk and reader. If it does, it would look like a clear disk about 8 inches in diameter and connected to the motor with a belt. If it does have one, clean it with a lint free cloth and rubbing alcohol. Sometimes the encoder gets dirty and skips a beat when running causing the printer to think it has jammed.
rdm01
Yeah, the encoder disk was dusty. It's been cleaned. Anyone know where to get parts? Can't seem to find anything that seems reputable. Found a place out of Ohio, but have phoned in twice and still no call back.
Compass Micro is in Washington. I can get parts for your machine but Compass Micro can ship directly to you and we generally don't sell Epson parts. The only problem is they may not be able to get parts for the large format solvent printers but they are worth a try. They are Epson's main parts distributor in the US.
C
ColoPrinthead
Guest
I'm not sure about the PF motor, but I used to get the CR Motor out of step error when I worked with 6000s and adding tension to the belt by moving the motor resovled the error.
Last time I spoke to Compass Mirco, they did not take returns fwiw.
