Epson Gs6000 Won't Power Up
liv2b100
Hi Guys,
My GS6000 turned off in the middle of a print today and won't turn back on.
Our building power is fine. Take up roller is on.
All machine fuses test OK.
Power going to power supply, and a relay on the power supply board makes a 'click' sound when we flip the switch, but that's it. No lights or sounds or fans anywhere else.
We can get in and replace a board - but does anybody know how to test which one it might be?
Any help would be appreciated.
Thanks,
liv
datoshway
Hi Guys,
Thanks,
liv
We had the same issue, if you hear the power supply and see the light on in the PS under the heater, it's most likley your main board
Marcumvustomllp
Ours shut down during print and makes clicking sound when button pushed to turn on or off nothing shows on lcd screen. Replaced power board and still does the same. The heater control board has a green light and a red light on. Would the heater control board keep printer from powering on?
datoshway
The main board has these tiny little fuses in them and if one of those fuses blow, it will cut off power and function to those components. Thats what happened to us and that what sounds like happened here.
mikenicee
Are the fuses you are talking about replaceable?
netsol
OF COURSE THE FUSE IS REPLACEABLE
but no one has said that one of them is bad
https://www.manualslib.com/manual/828293/Epson-Stylus-Pro-Gs6000.html
here is a link to the service manual
i have about 10 epsons in our warehouse (older ones 7600's through 9880's)
but have never done a system board repair
download (preferably PRINT) the manual, maybe PM me, i can work with you once we isolate an area of problem
if this was a wide format roland, i can tell you who has experience repairing system boards, but i am getting ahed of myself.
we were buying a not working gs6000 but when covid started the whole deal went sideways, but i know enough to be really helpful with this type of repair
chiiklyn
Im having the same issue here, mainboard has a fuse tagged "F11" that breaks and printer doesnt start.
If i replace the motherboard, it breaks f11 after a while, maybe one hour or maybe less
Anyone had found the solution?
