Epson surecolor s30670
Snydo
I have been running one daily since December 2012, and for our niche it is a perfect machine. They are fairly easy to maintain, and can pump out the jobs almost as fast as you can send them. It really depends on your needs though, if the bulk of your business is wraps and/or full color prints I would opt for a latex machine, if you do a lot of print/lam/plot stuff then the 30670 is a solid choice.
mpn
Do you run longer tiled jobs by any chance?
Snydo
I've done a 16 panel bus wrap with a fair amount of 4" text that lined up perfectly(Auto-tile flip on), and routinely print on Orajet calendered in 10' sections with hundreds of decals and everything usually plots fine.
mpn
Thanks for the info.
