epson
Discussion in 'Miscellaneous Printers' started by Cadmn, Apr 20, 2006.
  1. Cadmn
    Cadmn Very Active Member
    2,859
    is the epson 1270 capable of being turned into a decent decal printer ?
  2. OldPaint
    OldPaint Major Contributor
    i dont think so cadmn, it is an INKJET and they will not print on vinyl. alps or roland PC-12 only small printers that will lay onto vinyl.
  3. Cadmn
    2,859
    thanks OP I'm trying to get color decal out put under 5 digits. thats gonna be tough I think, gonna have to learn to laminate I'm sure can print outta my techtronix lazer but it scratches off.thanks for your time
  4. wes70
    wes70 Very Active Member
    1,657
    8
    38
    Oct 31, 2005
    Canada
    You could purchase an epson r1800 ($549.00) 13" wide pigment printer and then frog juice or laminate. You have to use coated vinyl. I have some epson laminated prints that have been outside for 2 years with no signs of fade. Hope this helps.
  5. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    weston which media are you using?
    I have not had very good results the media and adhesive bonding issues.
  6. OldPaint
    NOW YOU TELL US THAT!!! I just bought a new HP K850 $349.00 13x19 printer!!!!!!!!!!
    if you wana get a lazer that dont stratch off....look at the HP 2600N was on sale for $299.00 but is only 8/12 x 11 sheets.
  7. wes70
    1,657
    8
    38
    Oct 31, 2005
    Canada
    TresL, I use coated 4mil vinyl from Rexam. Roland, Kodak, Epson, Sihl, Avery and many other companies that make or distribute coated vinyl. Beacon graphics carry different brands.
  8. wes70
    1,657
    8
    38
    Oct 31, 2005
    Canada
    Make sure your printer has pigment inks. Dye inks will fade fast, even if laminated. Epson desktop printers (Durabrite & Ultrachrome inks) are the only desktop printers that use pigment ink.
  9. Kenny
    Kenny Member
    356
    Jul 15, 2003
    Texas
    Cadmn: In a pinch I used an Epson C84 with Durabrite inks on some full-color coro golf tee sponsor logos...here are links to the materials at papilio.com:
    Injet Waterproof Adhesive Vinyl
    Waterproof UV Laminate
    These guys are right up the road from you, North of Azle. I laminated and contour cut (20) by hand. They looked great and handled an early morning thunderstorm without any problems.
    You can pick up any of the letter/legal sized Epsons (c84 and up), or a 1280 to do 11x17 pretty cheap.
  10. Cadmn
    2,859
    no prob, I got to be in Arl on mondays wednesdays & fridays on davis & randall mill by noon. we outta meet & I workin on the file for You.
  11. Blazingsun
    Blazingsun Active Member
    858
    Any recomendations on roll Vinyl I have the epson r1800 which is capable of printing 13x44 it even has the roll attachment..
  12. TresL
    1,010
    Oct 24, 2005
    I have a bunch of the www.papilio.com inkjet paper, and have LOTS of issues with it bonding to the substrate.
    Had send around 200 of them back due to no adhesive on the back also.
    And getting the right color profile for the papilio took some time also.
    The laminate they have is a matte finish. I prefer to use a glossy overlam or clear glossy vinyl.
    I have a roll of HP I'm getting ready to run some test on.
    I also have a i9900 cannon for 13x19 photo prints...
    It does a VERY nice job.
  13. Kenny
    Kenny Member
    356
    Jul 15, 2003
    Texas
    Thanks for the update on papilio, haven't used them in awhile. I solved my color printing needs with a Versacamm.:biggrin:
  14. Kenny
    Kenny Member
    356
    Jul 15, 2003
    Texas
    Cool, I'm in Alvarado during the day, but planning on a Harbor Freight trip soon...I'll let you know and swing by on my way...
  15. Cadmn
    2,859
    ok I'll prolly be here if u can let me know a day ahead I'll surely be here if its not m,w,f
