Suggestions error 092
hamza
i had a error on my machine error 074 and when that went away after couple or restarting it was error 92 the carriage stopped got sucked i did clean the carnage the PF encoder it started but after like 10 yards it stopped again now is giving error 92 in the start
GTSTech_1
Both Error codes 074 and 092 have to do with the Y-Axis (CR Motor) not the X-Axis (PF motor). Watch what happens during operation, willing to bet your plunger (locking pin) is slightly bent and not allowing the carriage to move left. However would need more info from you to help......what printer model? 1204? 1304? 1324?
Just my .02
hamza
Ok i was about to place a order for the motor which is expensive can u guide me how to do a chck on it its mutoh 1638 , do you have a whtsapp numb ?
GTSTech_1
For the 1638 model there is no plunger on the leftside that unlocks the print carriage, instead you have a locking pin that is located top right of the print carriage. Remove the top right cover and watch the motions......my guess is the pin is not engaging/unlocking and the carriage tries to move the left but throws the E072 or E092 code. Sorry I don't have a whtsapp number or the app itself.
Just my .02
