a quick google search for "HP-GL ERROR 1 "
i found this hope it helps
http://www.signwarehouse.com/support/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=292&nav=0
I have the vinyl cutter set up and read through the manual. I can't seem to get it to cut. I keep getting the hp-gl error 1. I'm running it through the USB port. How do I tell it to use the USB port instead of the rs 232 cable? Is there a specific file type I have to use? I was trying to print something from Adobe Illustrator.
[FONT=times new roman,times,serif]
Thank you for contacting SignWarehouse technical support. With regard to the HPGL Error on your QE60 cutter , this is something that can be easily fixed on your cutter's display menu. [/FONT]
1) Load Vinyl into the cutter & lower pinch rollers[/FONT]
2) Choose ROLL 1, Enter & allow cutter to initialize[/FONT]
3) Press PREVIOUS several times until you get to COMMAND[/FONT]
4) Press ENTER[/FONT]
5) Now, ARROW DOWN to HPGL, then press ENTER[/FONT]
Pressing the PAUSE button will get to back to main screen & ready to cut.[/FONT]
If after doing this, you still get the error:[/FONT]
HOLD DOWN THE UP ARROW WHILE TURNING THE CUTTER OFF THEN ON AGAIN.[/FONT]
This will reset your cutter to default (as it was when you first got it). You'll select ENGLISH, etc. & Follow the HPGL steps once more before making another cut.[/FONT]
