Estimating yardage - what is left on the roll
Aunt LuLu
Aunt LuLu
Hi folks, I am lucky this time.....I was printing and did not realize that the end of the roll was near. The very end of the roll is/was stuck to the cardboard tube and stopped the forward motion of the media through the printer. This is not the first time and probably not the last time, this has happened.
Is there a way to estimate the amount left on the roll "before" it prints?
Laura - aka - Aunt LuLu
BigNate
I have owned Epsons, HPs and Canons for wide format - every machine had a feature to manage the length on the roll.. usually you tell it the length of the new roll and it keeps track. If you need to change media some printers print a barcode on the roll so it knows how much is left when it reloads the same roll... the HP we have does not, but it tells you how much is left when you unload. When programming jobs, I keep a notepad open and just subtract off the lengths of the images I send from the remaining length on the roll. (if you wait for all printing to stop, the displayed remaining length is a good figure, but while it is running, you need to be aware that the displayed length is the what should be currently on the roll, not taking into account any of the queued jobs.)
What printer are you using?
weight:
weigh an empty core, weigh a yard of vinyl
now weigh your roll and subtract the core and divide by yard weight.
you have X.yards remaining.
White Haus
Not a Newbie
The calculators seem like a good idea for laminate etc but getting the printers to count down from a full roll is the easiest/simplest method.
We'll just write remaining length on the corner before pulling the media off the printers.
Only issue there is that I usually round down and eventually you get to a point where the roll "should" be done and you've got a couple of yards left. Better that way than being short though.
