Question Everything I've learned about perf cut/die cut stickers
somcalmetim
We cut a lot of decals down into horizontal strips and then hand bomb with guillotine but I have taken normal print/lam/cut/weeded decals from the VG3 and contour cut them out of the backing with our c02 laser before...
Takes a lil extra time to set it up so the job cuts down into sheets that will fit in the laser with some sort of repeatable registration but they look good when done...I cut/weed them normally with the roland and then laser a small 0.06-.125" outline around them just through the backing to avoid lasering the vinyl itself...
  • Agree
Reactions: 1 user
VizualVoice
I just learned how to change my title status
I'm glad I read all the way to the last sentence because I was like, "OMG he's cutting vinyl on his laser. Wonder if he doesn't know or is obstinate?" :roflmao:
  • Agree
Reactions: 1 users
Bryce I
I'm Brie
I reckon we will invest in a plotter as we take on larger volume sticker orders. In the meantime, I've spent the last few months fiddling around with cutting stickers on the Roland VG-3 printer/cutter and I'm pleased to report that after much trial and error, we are now getting super clean, die cut stickers. Consistently! I will share this bit as it's own new thread, but here is everything we learned about how to make die cut stickers on the roland VG-3:
All of this also applies to the VG-2. The only difference I'm aware of is the cut strip on the VG-3 is a different material than the VG-2. The old one is solid black, and thinner. I was going through a lot of blades on that one. The new one is greenish clear and a bit thicker. It seems to be much more forgiving. If you're using a VG-2, I would recommend buying and installing a VG-3 cut strip.
Print files should have a regular, ContourCut cut path.
Use a 60 degree blade. Sharper than the default 45 degree blade. Insert 60 degree blade into blade holder, and twist blade holder counter-clockwise to retract the blade. You want the tip to be just barley poking out, almost not at all. Perform Crop-Cut Calibration tests, and make necessary adjustments. Then do pressure tests. I keep a scrap of laminated sticker media around for cut-pressure tests. Something the same thickness as the stickers you will be cutting, that you can keep close by and throw in the printer when getting a new blade dialed in.
Cut-Pressure Test
Import one sticker to versaworks as a test file and set it to cut-only.
Cut passes = 2
Pressure = 100
Cut the test sticker. If you've twisted the blade back in far enough, the 60 degree blade and 2 cut passes should kiss cut the vinyl but not the backing, like any other normal cut. You want to underdo it on the first one. Remove the blade holder and give it a little micro twist clockwise, bringing the blade out just a bit. Repeat the test cut with the same versaworks settings. Repeat this process until you get one where the sticker pops right out. Try dialing it back just a bit, and see if it still cuts through the backing. You're zeroing in on the money spot. See how far back you can twist the blade (counter-clockwise), and still get a clean cut. Once the blade is too far back in, the stickers will still be fully removeable, but will give a little resistance, a little tear. At that point, twist it clockwise again, one last time, and that should be the money spot.
Once it's dialed, and you have a bunch of stickers cutting at these settings, you can sit in front of the machine while it cuts row 2, and pop the stickers from row 1 out, like ripe berries. As a second option, when they cut just right, the stickers will stay attached to the sheet until you take it off the printer, and pull both ends taught, popping all the stickers out onto the table. No more weeding!
If the stickers are falling out into the machine while it's still cutting, the blade is out too far. If you're needing to tear them out, or put put any real effort into removing them, the blade is not out far enough.
After several thousand stickers, you can see a bit of wear on the strip, but we haven't had to replace it yet. I'd recommend keeping a few backup 60 degree blades on hand, but once it's dialed, you won't be going through them too fast.
  • Agree
Reactions: 1 user
DonutSlinger
Thats an interesting take. I have never tried cutting twice to do die cut before. Usually cut with our graphtec in perf mode or our summa in flex mode. Both offer benefits that are different from each other. Honestly prefer the graphtec bit it lacks good results with detailed die cuts. Summa cuts details nice and clean
