Exceedingly dumb question, re: temp files
threeputt
Ok, can anyone say for sure, if it's absolutely safe to dump any file with the extension .tmp? Doing some housecleaning and can't be sure.
I know, I know, it's probably a dumb question, but I'm a rookie on some things.
Techman
dump them all.
not needed..
usually they are constructed when you install software, but tmp files are not needed.
threeputt
Thanks techman, I was a little concerned. Some of them date back a couple of years, and are entitled like Set1A.tmp or Set8.tmp and I have no idea what that is.
I try and dump .tmp files regularly if I know what they are. (a downloaded movie, internet stuff or whatever)
mediaman
I have ccleaner on one computer - the IT guys at work warn against it deleting needed files such as software authorization codes, license info, etc. Can anyone tell me if this could present a problem or is ccleaner safe (or necessary)? Is there a better way to clean the temp folder other than manually?
Shovelhead
I run CCleaner
and my computer runs smooooooooooothhhhhhhhhhhhhhhh
WhiskeyDreamer
Professional Snow Ninja
not sure the name of the program, but we ran a cleaner program on one of our older PCs.....ended up having to uninstall and reinstall norton cause it deleted much needed files for norton to run...
side note: we've removed norton from all our systems due to having network problems with their software....it's kinda sad when you have to download off of norton's website in order to uninstall their software.....
