Excessive Print Size
Team Valhalla
I've got a graphic that is 27" by 33" that I want to print out on an SP-300V.
When I pull in to Versa Works and go to set up the print job, it tells me that the print area is something like 35" X 107". The "picture" of the graphic in Versa Works has a blue box around it that shows the excessive print area.
Is there a setting somewhere that I need to change?
Thanks in advance for any info.
SP
what are you exporting it as ? pdf or eps?
There may be somnething on the screen you can't see..
go to clip & tile in versaworks and move the lines closer to your artwork,,
ecoleejr
sounds like something in the artwork. If you have the actual file open it and select all and zoom out. Chances are their is something that is outside the image area that does not need to be there or something that needs to be clipped.
Team Valhalla
Exporting as an EPS.
Duh... I didn't think that there might be something floating out there. I'll check it.
Initially I just wondered if I was setting something up wrong with a graphic of this size.
SP
