Expanding a weighted outline to cut
wildhock
Hello All,
In Illy CS2 if I create say a star and create a second color outline with the stroke weight around it, what do I do to make the outside stroke weight its own path in order to cut it out?? Hope this make sense.
Thanks, Jon
sinetist
Another way to do this is to select the shape and go to Objects - Paths - Offset Path - then enter the amount of offset you want (plus or minus). You will get a new shape with the entered offset.
If you convert the strokes to outlines you get two paths for the stroke you converted (the inside and the outside of the stroke).
Rooster
If there's a fill you get three paths. Another one centered under the stroke for the fill.
Malkin
Sometimes the path you are working on is not closed, but the endpoints are stacked on each other so it looks a closed path. When you use "offest path" it makes a paths around the outside, cuts through the shape at the open ends, then continues around the inside in ones continuous path.
I find that I have to use the "outline stroke" instead to beat this, or manually join the open end points.
Mosh
Just remember the plotter is only going to cut the wireframe, not any effects added to the design like line weights. Always look at a design in the wireframe to make sure it is not going to need welded, common mistake I see in cut vinyl.
John Butto
a true welder
Could not find wireframe on my adobe illustrator tools.
