Export/Import filter combination
buckssigns
I'm trying to export curves from CorelX6 to an Adobe Illustrator file, then import said file to Omega 4.
So far haven't found an Export/Import filter combination that works.
My workround is to save the X6 file as legacy Corel 9, open it Corel 9 and export to Adobe Illustrator 88 file.
Hardly efficient!
Hope someone can help.
Tony Teveris
Does saving or publishing to a PDF help?
If you are saving to an *.AI file you may have to include some PDF or features into the file. I do not have x6 and most likely never will.
or are you saving to an EPS file?
GAC05
Quit buggin' me
I don't know about Omega but have you tried a copy and paste directly out of X6?
From X5 to CS5 it works the curves stay smooth with no extra nodes. Pasting into Flexi(ver8.6) makes a mess.
Might be worth a shot.
wayne k
guam usa
Fred Weiss
My best success from Corel to Gerber has always been using the Corel CMX format which Omega imports very well.
buckssigns
The first image is a screenshot as the file was, in X6, before export, then cut and paste, the export and import as cmx, then export and import as pdf.
Cut and paste did best but added hundreds of nodes. The others gave error messages or no results.
Thanks everyone for trying, I do appreciate it. Not sure what to do now, certainly dare not delete CorelDraw9!
Fred Weiss
Here are screen shots of text (converted to curves) in Corel and then Saved As Corel Presentation Exchange from CorelDRAW X3. The third and fourth screen shots are the CMX file opened in Omega 5 and nodes turned on. What I see is an uncorrupted, true to the original file in Omega.
GAC05
Quit buggin' me
Have you exporting/saving down to a version 3 ai file within X6?
I don't have X6 but for cut lines this has always worked for me from X5 and older.
AI v3 is no frills and just sends the paths & solid fills.
Maybe they "fixed" something in 6 and now it does not want to play well with others.
wayne k
guam usa
buckssigns
Thanks a million for that Fred.
With the help of your shots we are there. In X6, it seems you need to Save file with the "CMX - Corel Presentation Exchange Legacy" filter. Other that it all worked exactly as your step-by-step.
GAC05 I'll try that tomorrow, thanks – way past bedtime now!
buckssigns
Yes! That works too, Wayne.
Spotted a Compatability drop-down menu I hadn't noticed before and chose Adobe Illustrator 3JP.
I'm really spoilt for choice now.
Thanks again everyone.
