Export to Enroute option
Discussion in 'Flexi' started by Miki, May 6, 2005.
  1. Miki
    Miki New Member
    7
    I recently installed the free upgrade to my Flexi 7.5 and was told that the "export to Enroute" option would actually work now. I still can't get it to work. Anyone got any ideas?:help:
  2. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    What version of Enroute are you using? Also check wich version of 7.5 if it is new enough you can down load the new 7.6. I export to Enroute all the time, try starting Enroute first before you export I had to do that in one of the versions.
  3. Miki
    Miki New Member
    7
    I use Enroute 3 v2 and I upgraded my Flexi to 7.6 v1. I too have had to start my Enroute program before Flexi at times. I am wondering if I need to change a preference or something?
  4. Dennis Raap
    586
    Oct 5, 2003
    USA
    I am running Enroute 3.1 and Flexi 7.6 v1 just tried sending to my Enroute with it closed and it worked fine not sure what the problem is on your system.
