Exterior Sign Advice
archerdesign
Hi All! I was wondering if I could get some advice from some of you. I'm making a sign for a school which will be installed outside. I'm using 4mm Alupanel, and framing it with 2x4 stained Western Red Cedar. I'll be routering the middles of the 2x4's so the sign will slide in. Im worried about water collecting on the bottom 2x4. I live in a very wet climate so rain is always a concern. I was thinking of drilling drain holes? Or siliconing the base....but am afraid when the wood moves, so will the seal. Any tricks you can give me would be greatly appreciated. Thank you in advance,
Dave Archer
Sechelt, BC
Canada
Cap it with aluminum flashing. Drain holes will weep, clog with bugs and dirt and probably be the first place rot would start. Silicon will just move as the aluminum will expand and contract at a totally different rate than the wood, creating cracks constantly, so capping it would be your best bet, unless you can eliminate the piece entirely.
