Eyesore to Wallscape in 24 minutes
Lind SignSpring
From Blight
to Beauty in 24 Minutes!
attachment.php
Only BannerSpring can turn a crumbling wall into a flawless wallscape in 24 minutes.When the City of Mansfield, Ohio asked a property owner to repair a deteriorating wall, Lind SignSpring was key to the solution.
After some spot repairs to the wall perimeter, Lind crews then installed 1"x4" treated lumber to the perimeter, painted the wood black and installed BannerSprings around the perimeter.
We then installed a dynamic 7 oz vinyl simply pulling the BannerSpring tips into pre-marked holes around the vinyl perimeter. No grommets, clips, or bars to grip...... no wrinkles, ratchets sags or rips!
Like all SignSpring installations, it was picture perfect!
attachment.php
And even after 18 months, it still is flawless!
See the installation video for yourself, or go to our website to learn more!
Click Here To Watch Install Video!
letterman7
So instead of actually spending the money to fix a potentially dangerous wall, they spent the money on hiding it. Great solution! At least as it crumbles the banner should stop some of the debris.
Chriswagner92
So the wall was repaired, frame was built and painted, springs were installed and the banner hung in 24 minutes? impressive.
jfiscus
Rap Master
Shouldn't you let the paint cure more than 24 minutes before installing the hardware and banner?
Don't get me wrong, this looks like a great system/product for us to be able to sell, but don't tell me that from when you drove the truck onto the parking lot till when it left was 24 minutes.
Lind SignSpring
SignSpring is a Sign Installation System.
We put up the wallscape in 24 minutes...The wall poses no danger and is structurally safe.
Okay, so you want us to believe the banner cover went up in 24 minutes, but you're making it sound like that's all it took. Who put the perimeter bracing up to hold the banner ?? Wasn't that part of your job ?? How long did that take in addition to hanging the banner afterwards ?? Most buildings don't come with a banner hanging bracket system already in place. That should be calculated into the overall equation.
I don't know about your company, but most sign companies will put up a post or two before hanging a wood or metal sign and that's always figured in..... that is, putting in the posts. :toasting:
Brandon708
Come on guys this crumbling deteriorating wall is structurally safe.
So the install took 24 min. Did you prorate your hourly rate for such a quick install? :Big Laugh
Can I just buy the springs?
