60C is really high for Oracal vinyl. Is it wrinkling at all? Normally people run adhesive vinyls between 35-40C on the platen and leave the drier (fixer) at max.
The other thing that may be causing it is the print mode. The DX3 heads on this machine only have a 1/2" nozzle width, compared to 1" on the newer machines. In addition, there are only 64 nozzles per color, where the newer machines have 180-360 nozzles per color (depending on configuration).
So if you're trying to run at 180 or 360 dpi, don't even bother. The quality will be completely unacceptable no matter how hard you try. 720 is generally passable, and 720x1440 seems to be the usual production mode.
